SidPrice
My imported project build fails, how to fix it?
  • March 15, 2023
  • 11 replies
  • 4488 views
I have imported an STM32 project, created and debugged in the past using STM32CubeIDE. When I try to build this project in VSCode I see:
Executing task: Build
build task started....
"C:\Program Files\CMake\bin\cmake.EXE" --build "D:/DataRoot/Projects/IO Technologies/IHP Controller/build/debug/build"
The parameter is incorrect
CMake Error: Generator: execution of make failed. Make command was: &&
build finished with error(s).
No changes were made to the imported project.
Please advise how to proceed.
Sid
Best answer by robotdad
This looks like it might be an issue with our integration of vcpkg with the Embedded Tools extension. Can you report this here so we can dig into it?
https://github.com/microsoft/vscode-embedded-tools/issues
CsBe
Explorer II
March 28, 2023
Tryed with other network.. still the same.
> Bundled version of vcpkg: "2023-03-14-105f7f7e8a5ea10dfac9874ff9d1a6bacba5f454".
> Running vcpkg with arguments ["activate","--project","c:\\UserData\\modules\\firmware\\module-1","--json","C:\\Users\\user\\AppData\\Local\\Temp\\44c05403cd0283ca8dd043378a3e08aa"].
warning: vcpkg-artifacts is experimental and may change at any time.
node:internal/modules/cjs/loader:1078
 throw err;
Error: Cannot find module 'chalk'
Require stack:
- C:\Users\user\AppData\Local\vcpkg\artifacts-2023-03-14\node_modules\vcpkg-ce\ce\dist\cli\format.js
- C:\Users\user\AppData\Local\vcpkg\artifacts-2023-03-14\node_modules\vcpkg-ce\ce\dist\cli\command-line.js
- C:\Users\user\AppData\Local\vcpkg\artifacts-2023-03-14\node_modules\vcpkg-ce\ce\dist\main.js
  at Module._resolveFilename (node:internal/modules/cjs/loader:1075:15)
  at Module._load (node:internal/modules/cjs/loader:920:27)
  at Module.require (node:internal/modules/cjs/loader:1141:19)
  at require (node:internal/modules/cjs/helpers:110:18)
  at Object.<anonymous> (C:\Users\user\AppData\Local\vcpkg\artifacts-2023-03-14\node_modules\vcpkg-ce\ce\dist\cli\format.js:6:17)
  at Module._compile (node:internal/modules/cjs/loader:1254:14)
  at Module._extensions..js (node:internal/modules/cjs/loader:1308:10)
  at Module.load (node:internal/modules/cjs/loader:1117:32)
  at Module._load (node:internal/modules/cjs/loader:958:12)
  at Module.require (node:internal/modules/cjs/loader:1141:19) {
 code: 'MODULE_NOT_FOUND',
 requireStack: [
  'C:\\Users\\user\\AppData\\Local\\vcpkg\\artifacts-2023-03-14\\node_modules\\vcpkg-ce\\ce\\dist\\cli\\format.js',
  'C:\\Users\\user\\AppData\\Local\\vcpkg\\artifacts-2023-03-14\\node_modules\\vcpkg-ce\\ce\\dist\\cli\\command-line.js',
  'C:\\Users\\user\\AppData\\Local\\vcpkg\\artifacts-2023-03-14\\node_modules\\vcpkg-ce\\ce\\dist\\main.js'
Node.js v18.15.0
> Failed with exit code "1".
> Failed to activate environment at "c:\path\vcpkg-configuration.json".
