Memory alignment(structure Padding)
Bs.1
I am using STM32CubeIDE 1.6.0.
In my program for EEPROM read/write I have use structure but its takes too much size because of padding.
I tried with #pragma Pack, __attribute__((packed)), even by rearranging the structure member.
but there is no size reduction of structure .
Anyone having the solution to reduce this size??or any setting for compiler?
Any help will be highly appreciated..
Thanks in advance
Radosław
Senior III
Seems you are using this incorrectly. this must work.
