Memory alignment(structure Padding)
Bs.1
I am using STM32CubeIDE 1.6.0.
In my program for EEPROM read/write I have use structure but its takes too much size because of padding.
I tried with #pragma Pack, __attribute__((packed)), even by rearranging the structure member.
but there is no size reduction of structure .
Anyone having the solution to reduce this size??or any setting for compiler?
Any help will be highly appreciated..
Thanks in advance
1 REPLY 1
Radosław
Senior II
Seems you are using this incorrectly. this must work.
