2019-09-01 10:31 AM
I need to change all occurences of variable names. These names happen to be in a lot of .C and .H files hundred times. Source is from a collegue with "xz2b3" kinda variable names. I'd like to change variables to longer, more talkative names. Some IDE editors feature some Ctrl-Shift-F for this purpose. Any tip?
2019-09-25 01:07 PM
Hi Tamas,
Apparently, the new command is CTRL+H. I've found it on the top menu.
2019-09-25 01:07 PM
Hi Tamas,
2019-09-26 12:24 AM
I've only looked for the Edit menu, with lots of Find command. I missed the separate Search main menu item...
many thanks, Erik
Tamas
