Is there a way to reset the STM32CubeIDE back to the initial setup?
RCooke88
Hi All,
Is there a way to reset the IDE back to factory setup? I've somehow manged to screw things up enough that it's really not workable anymore.
Thanks,
Richard
AScha.3
if you just puzzled the windows or menus...
try:
>> To fix this, just remove this file inside your workspace:
>> .metadata/.plugins/org.eclipse.e4.workbench/workbench.xmi
>> Hope this solves the issue.
if more complex ... delete/uninstall and install new.
(your projects in workspace will remain / stay the same , if you start using old workspace with the new IDE . )
AScha.3
try:
