2020-02-12 06:53 AM
After downloading and installing CubeIDE, when trying to launch the app, Mac says the app is damaged and needs to go into the trash. Redownloading and doing it again results in the same issue. To fix this problem, open Terminal and enter the following "xattr -cr /Application/STM32CubeIDE.app" This resets all the attributes within the package to allow the app to run.
2020-02-12 07:26 AM
I had the same issue, thanks for sharing the fix. I was running this app from terminal instead of icon, and then it worked :)
