mehmet.karakaya
how to use spl instead of hal for starting F103 project
  • September 28, 2020
  • 1 reply
  • 655 views
hello forum,
I want to select SPL instead of HAL for a F103 project
how to do this ?
thank you
1 reply
Tesla DeLorean
Guru
September 28, 2020
Don't see that being a supported use case.
You'll likely need to hand build a project, pulling in the library source files, and pointing at the include files.
The GNU/GCC compiler should have no issue building SPL code.
You could make a proxy project for the specific part, and then remove and replace the HAL linkage, command line defines, etc.
