JWill.10
How to configure external clock in STM32CubeMx
  • January 30, 2023
  • 2389 views
According to the data sheet for this device, I should be able to attached an external High speed crystal instead of using the HSI RC. However, I can't seem to figure out how to do this using the STM32CubeMX utility.
AScha.3
so simple:
  1. set rcc
2 . set frequ.in clock tree and pll
0693W00000Y9S5hQAF.pngok ?
Javier1
Principal
January 30, 2023
as @AScha.3​ said, its quite straight foward.
Are you using any nucleo/discovery board? or you go custom
hit me up in https://www.linkedin.com/in/javiermuñoz/
