How to compile this code on a Nucleo
ATeli.1
H! I am trying to compile this program in a Nucleo (the source code is build for the specific version of the Nucleo that I am using) using STM32CubeIDE but the result on the console is Program “make” not found in the path.
5 REPLIES 5
STTwo-32
Hello @ATeli.1
It seems that your Path is not correct.
Check your installation path of CubeIDE.
Best Regards.
STTwo-32
I am pretty new, can you explain me how to check the installation path?
check the page 5 of UM2563:
Best Regards.
STTwo-32
To me seems to don’t have any problem, is this maybe related to the other toolchain. This is a screenshot of the error:
For me, it seems to be an installation path error. Can you try to uninstall and reinstall the IDE following the User Manual instructions. I think it should work.
Best Regards.
STTwo-32
