How to automatically open reference to @defgroup for @ref in HAL Doxygen comments in STM32CubeIDE? (To decipher "This parameter can be a value of @ref ...")
‎2023-05-26 7:08 AM
In HAL and LL drivers, lot of functions take parameters of type int, where only a Doxygen comment informs you what the possible values of the parameter are (e.g. "This parameter can be a value of @ref RCC_CSI_Config") and you have to manually search the source code for that @defgroup name or look it up in a manual separately.
This is obviously stupidly inconvenient and inefficient and ctrl+click behavior is needed to directly jump to the reference.
Is there any way to conveniently navigate the @ref references to their respective @defgroups in Eclipse?
Do other IDEs allow doing this in a simpler way? How are all of you engineers navigating the parameters without tearing your hair out?
STM32CubeIDE
‎2023-05-29 3:18 AM
Hello @MoistSignificantBit​
If I'm well understanding your request, you are asking for a feature to jump to the reference mentioned in a comment using the "ctrl + right click".
Such behavior is not possible for us to add as these are feature provided by ECLIPSE it self.
My advice is to use the "ctrl + h" to make a search for the reference manually.
KR,
Semer.
‎2023-05-29 3:18 AM
KR,
Semer.
