How can i use Build variables? pre-build shell script
Javier1
Principal
I want the IDE to save inside a buildinfo.h various const strings containing build timestamp names and other system variables.
0693W00000BaHb5QAF.pngBut im unable to use them inside my pre-build script:
#!/bin/sh
echo "this is the pre-build script!:D"
set _current_date=${current_date}
echo ${current_date}
echo ${_current_date}
echo "static const char BUILD_INFO[] = \"build_date=_current_date\";" > buildinfo.h
The pre-build script creates the build.infofile but the variable current_date is not shown...
we dont need to firmware by ourselves, lets talk
The eclipse variables can be substituted in the command line, but not in the script file itself.
Try to change the command so:
cd..;./script.sh ${current_date}
and in the script:
#!/bin/sh
set _current_date=$1
3 REPLIES 3
Javier1
Principal
I first tested
#!/bin/sh
    echo "static const char BUILD_INFO[] = \"build_date=${current_date}\";" > buildinfo.h
and this got generated inside buildinfo.h:
static const char BUILD_INFO[] = "build_date=";
It works when i use the date GNU command but i would like to use the IDE build variables.
cd Core/Inc
NOW=$(date +"%Y-%m-%d_%T")
echo "static const char BUILD_INFO[] = \"build_date="$NOW"\";" > buildinfo.h
and in the script:
#!/bin/sh
