Hi~I use STM32F103C8T6 to print string. The code was generated by CubeMX and I congfiged the USART1. And it can not to transmit any char. But USART2 and USART3 are OK! Why?
SBIG.1
PA9/PA10 GPIO pins and clock initialization look Ok
Some board level details might help here.
Send 0x55 pattern continuously, scope that.
waclawek.jan
Hardware is OK? Which pin are you using as USART1_Tx? How is it connected? Did you observe it using oscilloscope/logic analyzer?
Read out and check/post content of relevant USART/GPIO/AFIO registers.
