Error in final launch sequence: Setup exceptions
Krautermann
Senior II
I have searched around the ST community and I am not finding a solution to my problem:
I don't know what I did/changed but debugging is not working anymore! Every time when I try to debug, it's giving me this error message: Error in final launch sequence: Setup exceptions. See screenshot below.
Run does work without problem! I changed USB port and it's still the same.
I even deleted the debug configuration and made a new one and it's still the same.
1 REPLY 1
Rim LANDOLSI
Hello @Krautermann​ ,
At first , let me thank you for reporting this issue.
Could you please supply the GDB server log-file? It will be created if option “Log to file�? is enabled in the debug settings.
Rim
