EEPROM (M24M01E-F) Page accessing
  • June 3, 2024
  • 8 replies
  • 2243 views
For my project, I am using an M24M01E-F I2C EEPROM. My application requires writing and reading data page-wise. According to the datasheet, the EEPROM has a capacity of 1 Mbit (128 KB). I need clarification on how many pages I can able  write to using this EEPROM."
To clarify, the M24M01E-F EEPROM has a total of 512 pages, with each page being 256 bytes
Best answer by Peter BENSCH
All 512 pages are of course accessible, access to the pages should only be limited by the MCU used and its programme.
/Peter
Peter BENSCH
Welcome @Rishvana, to the community!
Correct, M24M01E contains 128KB EEPROM, which are divided into 512 pages with 256 bytes each.
Does it answer your question?
/Peter
RishvanaAuthor
Thank you, @Peter BENSCH,
Am I able to access all 512 pages?
Is there a page limitation when writing and reading?
because,
In my application, I am currently able to write only 416 pages in one write and read cycle. During the subsequent write cycle, a communication error occurs in both I2C read and write operations. I am using I2C communication with a clock frequency of 100 kHz.
Can you clarify this for me? Your help would be greatly appreciated.
Peter BENSCH
Peter BENSCHBest answer
/Peter
RishvanaAuthor
For our current project, we need to store some confidential information in the Identification Page section of the EEPROM (M24M01E-F). We would like to confirm if it is possible to use this specific section for our data storage and need a clarification about how to implement Identification page locking mechanism.
Could you please provide guidance on how we can store information in the Identification Page of the M24M01E-F EEPROM? Any insights or documentation on the process would be greatly appreciated.
Rishvana
Peter BENSCH
Yes, you can use the identification page for your purposes, but it can only be set to read-only and may therefore not be suitable for confidential information.
The procedure for accessing this identification page is described in the data sheet, section 4.4.
/Peter
RishvanaAuthor
Hi Peter,
Could you please provide sample code for accessing the identification page and the locking mechanism?
Thanks,
Rishvana
Peter BENSCH
See also this thread.
RishvanaAuthor
Thank you @Peter BENSCH
