CubeIDE 1.16.1 arm-none-eabi-gdb-version Error
Uloff.4
I am using CubeIDE version 1.16.1 to program and flash a STM32F433 MCU.
I am using a SEGGER J-Link flasher.
When I try to run the application I get the following error:
I have tried to manually set the workspace toolchain to local in the toolchain manager.
When I open the toolchain manager, I get an error that it has failed to fetch the toolchain list, in addition to four repositories that it cannot read:
Ignoring the message and setting the local toolchain as it follows
I get the same error when running the code on the MCU:
What should I try to do to fix the error?
12 REPLIES 12
Uloff.4
Hello @Ghofrane GSOURI
here is my log where i login in as normal user and try to run debugging:
2024-10-11 15:16:03,461 [INFO] Activator:177 - !SESSION log4j initialized
2024-10-11 15:16:22,357 [INFO] LogOutputStream:77 - [STDOUT_REDIRECT]
2024-10-11 15:16:24,907 [ERROR] ConfigurationRetriever:142 - IOException on connection: Connect timed out
2024-10-11 15:16:25,049 [INFO] ApplicationProperties:184 - Using Application install path: C:\ST\STM32CubeIDE_1.16.1\STM32CubeIDE\plugins\com.st.stm32cube.common.mx_6.12.1.202409122256
2024-10-11 15:16:25,064 [INFO] DbMcusXml:78 - Set database path to: C:\ST\STM32CubeIDE_1.16.1\STM32CubeIDE\plugins\com.st.stm32cube.common.mx_6.12.1.202409122256\\db\/mcu/
2024-10-11 15:16:25,065 [INFO] ApiDb:274 - Set plugin database path to: C:\ST\STM32CubeIDE_1.16.1\STM32CubeIDE\plugins\com.st.stm32cube.common.mx_6.12.1.202409122256\\db\/plugins/boardmanager/
2024-10-11 15:16:25,065 [WARN] ApiDb:259 - Overriding images path with different value:  => C:\ST\STM32CubeIDE_1.16.1\STM32CubeIDE\plugins\com.st.stm32cube.common.mx_6.12.1.202409122256\\db\/plugins/mcufinder/images/
2024-10-11 15:16:25,072 [INFO] ApiDb:250 - Set database path to: C:\Users\USER\.stmcufinder\plugins\mcufinder//mcu/
2024-10-11 15:16:25,073 [INFO] DbMcusAds:125 - Set database path to: C:\Users\USER\.stmcufinder\plugins\mcufinder//mcu/
2024-10-11 15:16:25,076 [INFO] CrossReferenceDbSqlite:203 - Set database path to: C:\Users\USER\.stmcufinder\plugins\mcufinder//mcu/cs/
2024-10-11 15:16:25,160 [INFO] RulesReader:64 - Compatibility file has been processed (297 Rules)
2024-10-11 15:16:25,233 [INFO] DbMcusXml:78 - Set database path to: C:\ST\STM32CubeIDE_1.16.1\STM32CubeIDE\plugins\com.st.stm32cube.common.mx_6.12.1.202409122256\\db\/mcu/
2024-10-11 15:16:25,233 [INFO] ApiDb:274 - Set plugin database path to: C:\ST\STM32CubeIDE_1.16.1\STM32CubeIDE\plugins\com.st.stm32cube.common.mx_6.12.1.202409122256\\db\/plugins/boardmanager/
2024-10-11 15:16:25,233 [INFO] ApiDb:261 - Set plugin images path to: C:\ST\STM32CubeIDE_1.16.1\STM32CubeIDE\plugins\com.st.stm32cube.common.mx_6.12.1.202409122256\\db\/plugins/mcufinder/images/
2024-10-11 15:16:25,233 [WARN] DbFile:41 - Overriding database path with different value: C:\Users\USER\.stmcufinder\plugins\mcufinder/ => C:\Users\USER\.stmcufinder\plugins\mcufinder
2024-10-11 15:16:25,233 [INFO] ApiDb:250 - Set database path to: C:\Users\USER\.stmcufinder\plugins\mcufinder//mcu/
2024-10-11 15:16:25,233 [INFO] DbMcusAds:125 - Set database path to: C:\Users\USER\.stmcufinder\plugins\mcufinder//mcu/
2024-10-11 15:16:25,233 [INFO] CrossReferenceDbSqlite:203 - Set database path to: C:\Users\USER\.stmcufinder\plugins\mcufinder//mcu/cs/
2024-10-11 15:16:25,299 [INFO] MainPanel:268 - HeapMemory: 367001600
2024-10-11 15:16:25,383 [INFO] DbMcusXml:78 - Set database path to: C:\ST\STM32CubeIDE_1.16.1\STM32CubeIDE\plugins\com.st.stm32cube.common.mx_6.12.1.202409122256\\db\/mcu/
2024-10-11 15:16:25,383 [INFO] ApiDb:274 - Set plugin database path to: C:\ST\STM32CubeIDE_1.16.1\STM32CubeIDE\plugins\com.st.stm32cube.common.mx_6.12.1.202409122256\\db\/plugins/boardmanager/
2024-10-11 15:16:25,384 [INFO] ApiDb:261 - Set plugin images path to: C:\ST\STM32CubeIDE_1.16.1\STM32CubeIDE\plugins\com.st.stm32cube.common.mx_6.12.1.202409122256\\db\/plugins/mcufinder/images/
2024-10-11 15:16:25,384 [WARN] DbFile:41 - Overriding database path with different value: C:\Users\USER\.stmcufinder\plugins\mcufinder/ => C:\Users\USER\.stmcufinder\plugins\mcufinder
2024-10-11 15:16:25,384 [INFO] ApiDb:250 - Set database path to: C:\Users\USER\.stmcufinder\plugins\mcufinder//mcu/
2024-10-11 15:16:25,384 [INFO] DbMcusAds:125 - Set database path to: C:\Users\USER\.stmcufinder\plugins\mcufinder//mcu/
2024-10-11 15:16:25,384 [INFO] CrossReferenceDbSqlite:203 - Set database path to: C:\Users\USER\.stmcufinder\plugins\mcufinder//mcu/cs/
2024-10-11 15:16:25,398 [INFO] ApplicationProperties:184 - Using Application install path: C:\ST\STM32CubeIDE_1.16.1\STM32CubeIDE\plugins\com.st.stm32cube.common.mx_6.12.1.202409122256
2024-10-11 15:16:25,399 [INFO] PluginManage:196 - Search for loadable plugins [exclusion list=, ]
2024-10-11 15:16:25,400 [INFO] PluginManage:310 - Check plugin analytics
2024-10-11 15:16:25,507 [INFO] AnalyticsPlugin:253 - Accepted Software Licenses:
2024-10-11 15:16:25,507 [INFO] AnalyticsPlugin:255 - Accepted CMSIS Pack Licenses:
2024-10-11 15:16:25,507 [INFO] AnalyticsPlugin:257 - Accepted Firmware Licenses: FW.F4.1.27.0,FW.H7.1.11.0,FW.F4.1.28.0
2024-10-11 15:16:25,510 [INFO] PluginManage:359 - Loaded plugin analytics (category:tool,tabindex:-1)
2024-10-11 15:16:25,510 [INFO] PluginManage:310 - Check plugin cadmodel
2024-10-11 15:16:25,527 [INFO] CADModel:105 - Init CAD model plugin
2024-10-11 15:16:25,527 [INFO] PluginManage:359 - Loaded plugin cadmodel (category:power,tabindex:5)
2024-10-11 15:16:25,527 [INFO] PluginManage:310 - Check plugin clock
2024-10-11 15:16:26,884 [INFO] PluginManager:220 - loadIPPluginJar : add stm32_wpan
2024-10-11 15:16:26,892 [INFO] IPUIPlugin:80 - create IPUIPlugin
2024-10-11 15:16:26,892 [INFO] PluginManager:220 - loadIPPluginJar : add tim
2024-10-11 15:16:26,902 [INFO] IPUIPlugin:80 - create IPUIPlugin
2024-10-11 15:16:26,902 [INFO] PluginManager:220 - loadIPPluginJar : add touchsensing
2024-10-11 15:16:26,908 [ERROR] ConfigurationRetriever:142 - IOException on connection: Connect timed out
2024-10-11 15:16:26,910 [INFO] IPUIPlugin:80 - create IPUIPlugin
2024-10-11 15:16:26,910 [INFO] PluginManager:220 - loadIPPluginJar : add tracer_emb
2024-10-11 15:16:26,919 [INFO] IPUIPlugin:80 - create IPUIPlugin
2024-10-11 15:16:26,919 [INFO] PluginManager:220 - loadIPPluginJar : add ts
2024-10-11 15:16:26,927 [INFO] IPUIPlugin:80 - create IPUIPlugin
2024-10-11 15:16:26,927 [INFO] PluginManager:220 - loadIPPluginJar : add tsc
2024-10-11 15:16:26,935 [INFO] IPUIPlugin:80 - create IPUIPlugin
2024-10-11 15:16:26,935 [INFO] PluginManager:220 - loadIPPluginJar : add ucpd
2024-10-11 15:16:26,943 [INFO] IPUIPlugin:80 - create IPUIPlugin
2024-10-11 15:16:26,944 [INFO] PluginManager:220 - loadIPPluginJar : add usart
2024-10-11 15:16:26,952 [INFO] IPUIPlugin:80 - create IPUIPlugin
2024-10-11 15:16:26,952 [INFO] PluginManager:220 - loadIPPluginJar : add usbx
2024-10-11 15:16:27,061 [INFO] CADModel:165 - CPN selected for project level
2024-10-11 15:16:27,061 [INFO] CADModel:114 - Register for checkConnection events
2024-10-11 15:16:27,061 [FATAL] Updater:334 - Updater called before beeing initialized
2024-10-11 15:16:27,061 [ERROR] CADModel:125 - Updater not yet initialized, retry later
2024-10-11 15:16:27,152 [INFO] CADModel:165 - CPN selected for project level
2024-10-11 15:16:27,152 [INFO] CADModel:114 - Register for checkConnection events
2024-10-11 15:16:27,152 [FATAL] Updater:334 - Updater called before beeing initialized
2024-10-11 15:16:27,152 [ERROR] CADModel:125 - Updater not yet initialized, retry later
2024-10-11 15:16:27,155 [FATAL] Updater:334 - Updater called before beeing initialized
2024-10-11 15:16:27,231 [FATAL] Updater:334 - Updater called before beeing initialized
2024-10-11 15:16:27,236 [INFO] DbMcusAds:53 - JSON generation date=Fri Sep 20 15:04:23 CEST 2024 (1726837463113)
2024-10-11 15:16:27,236 [FATAL] Updater:334 - Updater called before beeing initialized
2024-10-11 15:16:27,300 [WARN] DetailPanel:346 - Failed to get advertising image, set to default
2024-10-11 15:16:27,361 [FATAL] Updater:334 - Updater called before beeing initialized
2024-10-11 15:16:27,362 [FATAL] Updater:334 - Updater called before beeing initialized
2024-10-11 15:16:27,362 [WARN] DetailPanel:346 - Failed to get advertising image, set to default
2024-10-11 15:16:27,398 [ERROR] Updater:1164 - MainUpdater not yet initialized. External WinMGr cannot be set.
2024-10-11 15:16:27,402 [INFO] Updater:1100 - Updater Version found : 6.12.1
2024-10-11 15:16:27,416 [INFO] ApplicationProperties:184 - Using Application install path: C:\ST\STM32CubeIDE_1.16.1\STM32CubeIDE\plugins\com.st.stm32cube.common.mx_6.12.1.202409122256
2024-10-11 15:16:28,909 [ERROR] ConfigurationRetriever:142 - IOException on connection: Connect timed out
2024-10-11 15:16:29,081 [INFO] ThirdPartyUpdaterWithRetryManager:70 - Updater plugin not ready yet. [2/15]
2024-10-11 15:16:30,511 [ERROR] ConfigurationRetriever:142 - IOException on connection: Connect timed out
2024-10-11 15:16:31,593 [WARN] CheckConnectionManager:291 - Warning during Server Connection :  timeout Connect to sw-center.st.com:443 [sw-center.st.com/23.53.40.64, sw-center.st.com/23.53.40.26] failed: Connect timed out
2024-10-11 15:16:32,084 [FATAL] Updater:334 - Updater called before beeing initialized
2024-10-11 15:16:32,084 [ERROR] IntegrityCheckThread:130 - Cannot retrieve database content from updater: error 21
2024-10-11 15:16:32,084 [INFO] ThirdParty:978 - Integrity check success = false
2024-10-11 15:16:32,084 [INFO] IntegrityCheckThread:100 - exiting critical section [integrity check]
2024-10-11 15:16:32,084 [INFO] IntegrityCheckThread:103 - End integrity checks thread
2024-10-11 15:16:35,514 [ERROR] ConfigurationRetriever:142 - IOException on connection: Connect timed out
2024-10-11 15:16:35,606 [WARN] CheckConnectionManager:291 - Warning during Server Connection :  timeout Connect to sw-center.st.com:443 [sw-center.st.com/23.53.40.64, sw-center.st.com/23.53.40.26] failed: Connect timed out
2024-10-11 15:16:35,610 [INFO] MainUpdater:2873 - connection check result : 22
2024-10-11 15:16:35,611 [INFO] MainUpdater:290 - Updater Check For Update Now.
2024-10-11 15:16:35,611 [INFO] MicroXplorer:498 - Change Database Version : DB.6.0.121
2024-10-11 15:16:35,617 [INFO] McuFinderGlobals:63 - Set McuFinder mode to 2 (CubeIDE integrated)
2024-10-11 15:16:35,618 [INFO] UserAuth:417 - Internet connection configuration mode: 2
2024-10-11 15:16:35,625 [INFO] UserAuth:417 - Internet connection configuration mode: 2
2024-10-11 15:16:35,766 [INFO] CheckServerUpdateThread:120 - End of CheckServer Thread
2024-10-11 15:16:40,517 [ERROR] ConfigurationRetriever:142 - IOException on connection: Connect timed out
2024-10-11 15:16:48,697 [ERROR] ConfigurationRetriever:142 - IOException on connection: Connect timed out
2024-10-11 15:16:50,698 [ERROR] ConfigurationRetriever:142 - IOException on connection: Connect timed out
2024-10-11 15:16:52,699 [ERROR] ConfigurationRetriever:142 - IOException on connection: Connect timed out
2024-10-11 15:17:13,545 [WARN] CheckConnectionManager:291 - Warning during Server Connection :  timeout Connect to sw-center.st.com:443 [sw-center.st.com/23.48.23.46, sw-center.st.com/23.48.23.61] failed: Connect timed out
2024-10-11 15:17:15,550 [WARN] CheckConnectionManager:291 - Warning during Server Connection :  timeout Connect to sw-center.st.com:443 [sw-center.st.com/23.48.23.46, sw-center.st.com/23.48.23.61] failed: Connect timed out
2024-10-11 15:17:15,551 [INFO] MainUpdater:2873 - connection check result : 22
2024-10-11 15:17:17,560 [WARN] CheckConnectionManager:291 - Warning during Server Connection :  timeout Connect to sw-center.st.com:443 [sw-center.st.com/23.48.23.46, sw-center.st.com/23.48.23.61] failed: Connect timed out
2024-10-11 15:17:19,564 [WARN] CheckConnectionManager:291 - Warning during Server Connection :  timeout Connect to sw-center.st.com:443 [sw-center.st.com/23.48.23.46, sw-center.st.com/23.48.23.61] failed: Connect timed out
2024-10-11 15:17:19,566 [INFO] MainUpdater:2873 - connection check result : 22
2024-10-11 15:17:32,433 [WARN] CheckConnectionManager:291 - Warning during Server Connection :  timeout Connect to sw-center.st.com:443 [sw-center.st.com/23.53.40.26, sw-center.st.com/23.53.40.64] failed: Connect timed out
2024-10-11 15:17:34,438 [WARN] CheckConnectionManager:291 - Warning during Server Connection :  timeout Connect to sw-center.st.com:443 [sw-center.st.com/23.53.40.26, sw-center.st.com/23.53.40.64] failed: Connect timed out
2024-10-11 15:17:34,439 [INFO] MainUpdater:2873 - connection check result : 22
2024-10-11 15:17:36,446 [WARN] CheckConnectionManager:291 - Warning during Server Connection :  timeout Connect to sw-center.st.com:443 [sw-center.st.com/23.53.40.26, sw-center.st.com/23.53.40.64] failed: Connect timed out
2024-10-11 15:17:38,449 [WARN] CheckConnectionManager:291 - Warning during Server Connection :  timeout Connect to sw-center.st.com:443 [sw-center.st.com/23.53.40.26, sw-center.st.com/23.53.40.64] failed: Connect timed out
2024-10-11 15:17:38,450 [INFO] MainUpdater:2873 - connection check result : 22
2024-10-11 15:17:40,471 [WARN] CheckConnectionManager:291 - Warning during Server Connection :  timeout Connect to sw-center.st.com:443 [sw-center.st.com/23.53.40.26, sw-center.st.com/23.53.40.64] failed: Connect timed out
2024-10-11 15:17:42,478 [WARN] CheckConnectionManager:291 - Warning during Server Connection :  timeout Connect to sw-center.st.com:443 [sw-center.st.com/23.53.40.26, sw-center.st.com/23.53.40.64] failed: Connect timed out
2024-10-11 15:17:42,480 [INFO] MainUpdater:2873 - connection check result : 22
2024-10-11 15:17:44,484 [WARN] CheckConnectionManager:291 - Warning during Server Connection :  timeout Connect to sw-center.st.com:443 [sw-center.st.com/23.53.40.26, sw-center.st.com/23.53.40.64] failed: Connect timed out
2024-10-11 15:17:46,496 [WARN] CheckConnectionManager:291 - Warning during Server Connection :  timeout Connect to sw-center.st.com:443 [sw-center.st.com/23.53.40.26, sw-center.st.com/23.53.40.64] failed: Connect timed out
2024-10-11 15:17:46,497 [INFO] MainUpdater:2873 - connection check result : 22
2024-10-11 15:18:22,292 [WARN] CheckConnectionManager:291 - Warning during Server Connection :  timeout Connect to sw-center.st.com:443 [sw-center.st.com/23.213.161.27, sw-center.st.com/23.213.161.22] failed: Connect timed out
2024-10-11 15:18:24,296 [WARN] CheckConnectionManager:291 - Warning during Server Connection :  timeout Connect to sw-center.st.com:443 [sw-center.st.com/23.213.161.27, sw-center.st.com/23.213.161.22] failed: Connect timed out
2024-10-11 15:18:24,298 [INFO] MainUpdater:2873 - connection check result : 22
2024-10-11 15:18:26,303 [WARN] CheckConnectionManager:291 - Warning during Server Connection :  timeout Connect to sw-center.st.com:443 [sw-center.st.com/23.213.161.27, sw-center.st.com/23.213.161.22] failed: Connect timed out
2024-10-11 15:18:28,306 [WARN] CheckConnectionManager:291 - Warning during Server Connection :  timeout Connect to sw-center.st.com:443 [sw-center.st.com/23.213.161.27, sw-center.st.com/23.213.161.22] failed: Connect timed out
2024-10-11 15:18:28,308 [INFO] MainUpdater:2873 - connection check result : 22
2024-10-11 15:18:35,777 [WARN] CheckConnectionManager:291 - Warning during Server Connection :  timeout Connect to sw-center.st.com:443 [sw-center.st.com/23.213.161.27, sw-center.st.com/23.213.161.22] failed: Connect timed out
2024-10-11 15:18:37,782 [WARN] CheckConnectionManager:291 - Warning during Server Connection :  timeout Connect to sw-center.st.com:443 [sw-center.st.com/23.213.161.27, sw-center.st.com/23.213.161.22] failed: Connect timed out
2024-10-11 15:18:37,784 [INFO] MainUpdater:2873 - connection check result : 22
2024-10-11 15:18:39,788 [WARN] CheckConnectionManager:291 - Warning during Server Connection :  timeout Connect to sw-center.st.com:443 [sw-center.st.com/23.213.161.27, sw-center.st.com/23.213.161.22] failed: Connect timed out
2024-10-11 15:18:41,791 [WARN] CheckConnectionManager:291 - Warning during Server Connection :  timeout Connect to sw-center.st.com:443 [sw-center.st.com/23.213.161.27, sw-center.st.com/23.213.161.22] failed: Connect timed out
2024-10-11 15:18:41,793 [INFO] MainUpdater:2873 - connection check result : 22
Uloff.4
Could you understand anything from my log?
I also wanted to ask if you could give me all the URLs I need to allow the STM32 Cube IDE to run properly?
Thanks for your help.
Hawkeye
I had the same problem. I had to reinstall the ide. My guess is another update coming soon.
