compling generated code by MCSDK by c++ included errors that must be be corrected for use
Ofer
I tried compiling the generated code of the MCSDKand compiling it by C++ compiler, but the error at the revup_ctrl.h file:   pHandle->pCurrentPhaseParams = MC_NULL;
prevent such compilation.
Will it be fixed soon ?
Pavel A.
Which error? Please include the exact error message.
If you compile with C compiler, will this error occur? Is it something specific to C++ vs. C ?
Not tomorrow :)
I'm getting this error at MCSDK/MCLib/Any/Inc/revup_ctrl.h file , line 209
it happens with C++ compilation only.
Then I'm afraid the reply will be just keep using C, as the MCSDK likely was written in C and none of the user have complained yet.
You can also fix the error yourself, in your copy of the software.
You can open a support ticket, but the response time is far from immediate.
Good luck!
