2023-02-12 11:05 PM
I have a big project in C that was created by other people, it builds and run well on STM32CubeIDE. I want to create DLL file out of this to expose the functions used inside so that it can be used by other programming languages.
2023-02-14 2:52 AM
Hello @SChen.24
First let met thank you for posting.
If you are really meaning you need to generate DLL files, then the answer is you can't do it as those files exist for application running in Windows environment.
However you can create static libraries with STM32CubeIDE and share them in other project.
For more details, check the STM32CubeIDE user manual UM2609 - Rev 7 chapter 2.2.2 Creating a new STM32 static library project.
Hope this answer your question.
KR,
Semer.
2023-02-14 2:52 AM
Hello @SChen.24
KR,
Semer.
