Can't install 'Devstyle' on STM32Cubeide V1.18.1!
‎2025-05-02 3:04 AM
My 'OS' is Debian12.
And as you can see from the question above, I'm having trouble installing the theme for CubeIDE v1.18.1
See attached screen.
STM32CubeIDE
‎2025-05-02 5:07 AM - edited ‎2025-05-02 5:08 AM
I run MxLinux (up to date).
Seems there is a problem in access to "marketplace" in 1.18.1 ;
can you open marketplace and search/select ...anything ?
‎2025-05-02 5:13 AM
No, it takes a long time to load and eventually does not connect to the marketplace!
Same behavior in CubeIDE v1.15.1.
PS, I need to customize CubeIDE appearance and fonts, because by default it is not possible to work at all! Maybe someone knows how to configure CubeIDE manually without DevStyle?
‎2025-05-02 5:53 AM - edited ‎2025-05-02 6:20 AM
...this is how my IDE is looking:
Using any new plugins from "market" can be dangerous - i had to delete and install IDE new,
after testing some plugins - changes could not be reversed !
So more save: use the settings, that are already here: menu -> window -> preferences
- first:
- then: many ...editor, debug etc.
- and the syntax colors you like:
- and what it shows in menu and tollbars :
/for every perspective ! / edit / debug / Mx
menu-> window -> perspective -> customize...
btw - what i like : mark occ. of sel. text
- and breakpoints better visible:
-> here : marked text "fresult" and a breakpoint
