2019-06-21 02:39 PM
Hi Community,
What C++ version does CubeIDE supports?
Is C++ 17 supported?
What compiler does it actually use? Is it GCC?
Are modern C++ features like 'vector<string>' supported?
2019-06-21 02:54 PM
The version of the compiler that CubeIDE uses is 7.3.1, the 2018, q2 update.
According to this site
https://en.cppreference.com/w/cpp/compiler_support
This compiler supports all the core c++17 features. Not so sure about the C++ library support as I have not much experience in using C++ on microcontrollers. Just starting to get into this now :)
Hope this helps
