Build configurations setup
Angel1
I am using STM32CubeIDE to develop our project over a stm32l4x controller. I have different build configurations, and I would like to know if it is possible to define a different output file name for each build configuration.
Best regards and thank you
Angel
5 REPLIES 5
KnarfB
Principal III
Project Properties > C/C++ Build > Settings > Build Artifact > Artifact Name:
Angel1
Great, thank you for your quick answer.
I have one more question: I have also a "Pinout & Configuration" that is unique for all build configurations. Is it possible to assign different ".ioc" definitions for each build configuration.
Angel
Sorry, no idea how that could be done.
KnarfB
Can be done, but only manually.
1. define a distinct preprocessor symbol in each configuration and use #ifdef's.
2. Generate a set of files from each .ioc per config, then in each configuration exclude from build files of other configurations.
It looks pretty messy, but works.
Angel1
Hi Pavel,
Thank you for your help, I will check if this fit our requirements.
Best regards
