2025-03-20 10:43 AM
Can anyone confirm that the Build Analyzer in the CubeIDE works when using the CMake toolchain? For compatibility reasons I'm currently stuck at IDE version 1.16.1. I created a fresh CMake Project for a Nucleo board (U545). It creates the elf and map files just fine but the Build Analyzer stays empty. (Yes, I tried the refresh button...)
If someone could confirm that a newer IDE version does the job, I'll try to convince the project team. Or what I could do to make it work in 16.1. Thanks!
2025-03-20 2:11 PM
If, after building, you right click the project and refresh, then refresh the build analyzer, does it work? It might be looking for the elf at a specific location (e.g. Debug/project.elf), but I'm not sure if that's configurable. Seems like its behavior was hard coded for typical projects.
2025-03-20 2:11 PM
2025-03-21 12:19 AM
It seems that I missed the refresh on the project! Thanks a lot.
