Would like to be able to use Build Analyzer.
‎2024-07-25 5:15 AM - edited ‎2024-07-25 5:16 AM
I hope to use the same Build Analyzer in VSCode as in the IDE, which allows developers to more clearly see the use of flash and memory. I have tried to use GPT to write a plugin, but the effect is not good, and I don't understand the JS language well, so it is difficult to develop it by myself.
My mother tongue is not English, please forgive me if it is not easy to understand.
- Labels:
VSCode for STM32
‎2025-01-07 2:11 AM
Update: Build analyzer will come during 2025 Q1/Q2. It works internally already.
But due to architectural changes and legal constraints we cannot deploy it yet.
‎2024-07-25 5:40 AM - edited ‎2024-07-25 5:41 AM
If you want to convince (or sponsor) someone to make this tool for VS Code - you're welcome! A good idea.
(but most likely it already exists, because it is based on well known format of linker .map file, maybe .ld files too).
‎2024-07-25 6:07 AM
Yes, it parses the map file format, but I haven't found anything like it in the extension marketplace, nor any relevant content through search engines. Perhaps reverse-engineering the official Java plugin could be an option, but I haven't learned Java yet either.
‎2024-10-09 11:09 PM
Hi!
I also lack this functionality a lot in VS Code.
Any news regarding recommended extensions etc?
‎2024-10-10 12:45 AM
I don't have any new information.
Perhaps there are fewer people using VS Code for this specific purpose.
‎2024-12-17 10:48 AM
Hi! I started using VSCode as an alternative to CubeIDE and came across this topic while looking for a build analyzer for VSCode. I’m young and inexperienced, so the idea of creating my own plugin for VSCode doesn’t scare me yet. Were you able to achieve much? Maybe I don’t need to start from scratch?
‎2024-12-17 12:11 PM
Just use CubeIDE or other IDE that has the analyzer ready, and be happy?
A lot of open-source VS code extensions exist, one can peruse any of these for a prototype.
‎2025-01-07 2:11 AM
‎2025-01-07 2:26 AM
Thank you so much for your efforts.
‎2025-01-09 7:17 AM
At the moment I have this. What do you think?
