STM32 VSCode extension (MCUs)
Issue with Linker Script in CubeMX 6.12.1
Dear users   After upgrading to STM32CubeMX 6.12.1 some of you reported limitations for CMAKE generated projects. We encourage you therefore to stick with the 6.12.0 for those encountering this limitation until the publication of the 6.13.0.    Thank...
New STM32 VSCode extension V2.1.0 released
Changelog Version 2.1.0 Added support for the following advanced STM32 devices TrustZone devicesDual Core devicesBootflash devices STM32CubeMX v6.12.0 is required to generate CMake projects for these advanced devicesSTM32CubeCLT v1.16.0 is required t...
Imported code does not build in VScode.
Hi,I have always used the STM32cudeIDE but now trying to use the new STM32 VScode extension. But to start with, I have not been able to build the imported code. [build] [1/1] Linking C executable GM_PRJ01_LL01_FRM.elf [build] FAILED: GM_PRJ01_LL01_FR...
Paul. A by Associate
  • 1862 Views
  • 4 replies
vcpkg configuration
Hello,Every time I try to import a project to VSCode I get the following vcpkg configuration error:read_contents("C:\Users\<username>\AppData\Roaming\Code\User\globalStorage\ms-vscode.vscode-embedded-tools\vcpkg\root\scripts\vcpkgTools.xml"): no such...
CRebe.1 by Associate II
  • 5814 Views
  • 11 replies
  • 1 kudos
Where download firmware for Nucleo H743ZI2
Hello,I would greatly appreciate it if someone could assist me in locating the most up-to-date firmware for the Nucleo H743ZI2 board. Presently, my board is running on the following firmware:Version: 0221 Build: Aug 23 2019 16:25:00Unfortunately, I a...
defcon9 by Associate
  • 1012 Views
  • 4 replies
