Change the IOC UI fonts
SS.33
0693W00000WKBxMQAX.pngI want to change the pin configuration fonts, I tried with colors and fonts tabs but nothing worked
1 REPLY 1
Sara BEN HADJ YAHYA
Hello @Community member​ ,
Welcome to the community and thanks for your feedback,
You can change the Pinout colors in Pinout View Colors tab, it can be found under Pinout -> Pinout View Colors.
I hope this helps !
If your issue is solved, please close this post by clicking the "Select as Best" button. This will help other members of the community find this response more quickly ��
Sara.
