2022-12-04 10:43 PM
I want to change the pin configuration fonts, I tried with colors and fonts tabs but nothing worked
2022-12-08 02:40 AM
Hello @Community member ,
Welcome to the community and thanks for your feedback,
You can change the Pinout colors in Pinout View Colors tab, it can be found under Pinout -> Pinout View Colors.
I hope this helps !
If your issue is solved, please close this post by clicking the "Select as Best" button. This will help other members of the community find this response more quickly
Sara.
