2021-06-11 1:24 AM
I test commands
echo 97 > /sys/class/gpio/export
echo out > /sys/class/gpio/gpio97/direction
echo 1 > /sys/class/gpio/gpio97/value
echo 0 > /sys/class/gpio/gpio97/value
", the value on the pin PD.1 can't change.
Test command:
gpioset gpiochip3 1=1
gpioset gpiochip3 1=0
" the value on the pin PD.1 can change.
Please advise how to solve the issue on "/sys/class/gpio".
Thanks,
QiZhang
2021-06-14 2:33 AM
Hi @zqizh.1 ,
OpenSTLinux is not supporting /sys/class/gpio but only the /dev/gpiochip* devices together with libgpiod.
See https://wiki.st.com/stm32mpu/wiki/How_to_control_a_GPIO_in_userspace
Olivier
2021-06-14 2:33 AM
Hi @zqizh.1 ,
Olivier
