2023-06-08 09:17 AM - edited 2023-11-20 03:38 AM
I see the following when I try to download the latest or select any other version of the tool
2024-04-04 12:43 AM
If you suspect regional issues test using a VPN connection.
2023-06-08 09:32 AM
Hi @VTver.1
Do you login to the site before trying to download the tool?
Best regards,
--JM
2024-04-04 12:39 AM
For the past three days, I've encountered an issue. Whenever I attempt to download from the website, a message appears stating, 'This software is not available for download.' Even when testing it on my friend's PC, the same issue persists. I'm unable to download STM32 Cube MX from the website. Is this limited to certain regions? I reside in Pakistan (Asia). Please provide an update on this matter and kindly resolve this issue.
2024-04-04 12:43 AM
2024-04-04 11:23 PM
VPN worked. Why not working in Pakistan?
2024-05-06 07:29 AM
Same issue, maybe restricted in Pakistan
