2019-08-06 07:05 PM
The software of the company is developed based on QT framework. Due to some limitations of the framework, opengles cannot be better used. Can you use linuxfb to run QT program?I can't find the /dev/fb0 interface😀
2019-08-21 01:10 AM
ST is using drm/kms interface for the display and we will encourage are customer to do the same.
see: https://wiki.st.com/stm32mpu/wiki/DRM_KMS_overview
The frame buffer interface is deprecated but you may activate it in the kernel I guess.
