STM32MP157 input capture gives wrong value
alex_vm
I've tried measure period of  GPS PPS which is very high accuracy. I'm using TIM5 input capture mode, reset slave mode. The TIM5 CCR1 gives value 208877646 that is wrong because I use high accurate generator for sys clock. The right value is about 209000000. So maybe anyone meet the problem?
Thanks,
Alex.
PatrickF
Hi @alex_vm ,
could you check the real TIM5 clock using :
 grep -E "clock|tim5_k" /sys/kernel/debug/clk/clk_summary
in starter package, the clock is defined as 208877930Hz, so your results sound good with this value (tolerance of HSE oscillator).
Regards.
PatrickF
Hi @alex_vm ,
Regards.
Hi Patrick
Thank you for your help. I forget to write in the start topic I'm using M4 in standalone mode .But as I think the cause is a same.
BR
