Rootfs size expansion
‎2021-07-09 10:30 PM
Hi ,
How can i increase the size of rootfs correctly?
I tried using gparted , but it looks like the tf-a iss't very happy with it and tries to reset it in correct way. So i would like to understand how can i increase its size more correctly since installing a lot of packages causes low disk space in rootfs and i would like to leverage space left on other drives to be used.
Any leads will be highly appreciated.
- Labels:
STM32MP15 Lines
‎2021-08-27 5:21 AM
Hello @NPal.2​
This topic may help you: https://community.st.com/s/question/0D53W00000jm0GnSAI/increasing-the-rootfs-size-on-a-stm32mp157fdk2
Best regards,
--JM
‎2021-07-11 11:42 PM
Hello @NPal.2​
if possible, you can try to flash your board with the «extensible» flashlayout (*-extensible.tsv). Extensible flashlayout does not flash userfs partition to extend the rootfs partition to the size of the sdcard.
If not, you have to change the value of the variable IMAGE_ROOTFS_MAXSIZE in your image parameter (see the definition of this variable in the layer meta-st/meta-st-stm32mp in the file conf/machine/include/st-machine-common-stm32mp.inc.
Best regards,
--JM
In order to give better visibility on the answered topics, please click on 'Select as Best' on the reply which solved your issue or answered your question. See also 'Best Answers'
‎2021-07-12 12:38 AM
Hi @Jean-Marc B​ : Thanks for response. Let me try this and see what is happening.
‎2021-07-12 12:58 AM
Hi NPal.2 (Community Member)
You could also refer to this:
https://wiki.st.com/stm32mpu/wiki/How_to_populate_the_SD_card_with_dd_command
Here you can update the script "create_sdcard_from_flashlayout.sh" and change the field DEFAULT_ROOTFS_PARTITION_SIZE
according to your needs.
Best Regards
Olivier
‎2021-07-12 1:41 AM
Thanks @OlivierK​ : I think this sounds more good. I will definitely give this a try.
‎2021-07-20 6:10 AM
‎2021-08-25 3:25 AM
Hi @Jean-Marc B​ and @OlivierK​ :
I tried above suggestion of modifying IMAGE_ROOTFS_MAXSIZE to value for 1.5GB. But it looks like system does not take it. Running df -h shows the root storage limited to 660MB . However doing lsblk shows it has size of 1.5GB. How to fix this ? Root partition still is limited to 660MB.
Filesystem Size Used Avail Use% Mounted on
/dev/root 660M 587M 24M 97% /
devtmpfs 181M 0 181M 0% /dev
tmpfs 246M 64K 245M 1% /dev/shm
tmpfs 246M 17M 229M 7% /run
tmpfs 246M 0 246M 0% /sys/fs/cgroup
tmpfs 246M 0 246M 0% /tmp
/dev/mmcblk0p2 58M 9.9M 44M 19% /boot
/dev/mmcblk0p3 15M 6.8M 6.7M 51% /vendor
tmpfs 246M 164K 245M 1% /var/volatile
/dev/mmcblk0p5 120M 8.9M 103M 8% /usr/local
tmpfs 50M 0 50M 0% /run/user/0
root@stm32mp157a-visionsom-rgb-emmc-mx:/usr/local# lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
mmcblk0 179:0 0 3.7G 0 disk
|-mmcblk0p1 179:1 0 4M 0 part
|-mmcblk0p2 179:2 0 64M 0 part /boot
|-mmcblk0p3 179:3 0 16M 0 part /vendor
|-mmcblk0p4 179:4 0 1.5G 0 part /
`-mmcblk0p5 179:5 0 2.1G 0 part /usr/local
mmcblk0boot0 179:16 0 2M 1 disk
mmcblk0boot1 179:32 0 2M 1 disk
‎2021-08-27 5:21 AM
Hello @NPal.2​
Best regards,
--JM
‎2021-09-08 6:39 AM
Thanks @Jean-Marc B​ This really helps...!!
