2023-11-25 3:18 PM
Trying to merge a custom stm32mp153c board to the new BSP (6.1-yocto-mickledore), OP-TEE panics:
F/TC:0 0 probe_driver_node:391 Probing stm32mp1-cpu-opp on node cpu0-opp-table
F/TC:0 0 get_supply_phandle:114 cpu: supplied by 4
F/TC:0 0 __clk_enable:1174 Clock 140 has been enabled
F/TC:0 0 __clk_disable:1187 Clock 140 has been disabled
F/TC:0 0 pmic_get_voltage:220 buck1: get volt
D/TC:0 0 stm32_bsec_find_otp_in_nvmem_layout:644 nvmem part_number_otp = 1: 1 bit offset: 0, length: 8
D/TC:0 0 stm32mp1_cpu_opp_get_dt_subnode:291 Found OPP 0 (650000kHz/1200mV) from DT
F/TC:0 0 regulator_set_voltage:299 buck1 1200mV
F/TC:0 0 pmic_set_voltage:233 buck1: set volt
F/TC:0 0 regulator_set_voltage:327 buck1 0uS
E/TC:0 0 set_voltage_then_clock:134 Failed to set clock
E/TC:0 0 Panic at core/arch/arm/plat-stm32mp1/cpu_opp.c:137 <set_voltage_then_clock>
Please see the full bootlog attached.
Any ideas how to fix this?
2023-11-26 5:26 AM
Quick update: This issue with my custom STM32MP153C board has been resolved. The solution was to use the clock settings from the ST development kits instead of CubeMX's.
2023-11-26 5:26 AM
