How to set pinctrl_z port to unsecure in device tree as default?
Dat Tran
Senior II
Hi, I would like to set all 8 pins in port Z to unsecure so i use these pins as other ports.
I read data sheet portz is set to secure mode as default after reset. And I tried write into it and system crashed.
Olivier GALLIEN
Hi @Community member?
GPIOZ can be unsecure adding this line in TF-A DTS :
DECPROT(STM32MP1_ETZPC_GPIOZ_ID, DECPROT_NS_RW, DECPROT_UNLOCK)>;
Refer to :
ETZPC device tree configuration - stm32mpu​
Olivier
Olivier GALLIEN
Olivier GALLIEN
Refer to :
Olivier
Olivier GALLIEN
Dat Tran
Senior II
yes, thank you a lot. that did help
