Error during SDK extraction
‎2025-01-02 2:50 AM - edited ‎2025-01-03 5:30 AM
This page mentions that you are supposed to use tar xf for SDK extraction. Unfortunately this doesn't work for the latest SDK 6.6 (scarthgap), it looks like the SDK is just a tar archive and not compressed.
$ tar xf en.SDK-x86_64-stm32mp1-openstlinux-6.6-yocto-scarthgap-mpu-v24.11.06.tar.gz
tar: This does not look like a tar archive
tar: Skipping to next header
tar: Exiting with failure status due to previous errors
$ tar xzf en.SDK-x86_64-stm32mp1-openstlinux-6.6-yocto-scarthgap-mpu-v24.11.06.tar.gz
$ file en.SDK-x86_64-stm32mp1-openstlinux-6.6-yocto-scarthgap-mpu-v24.11.06.tar.gz
en.SDK-x86_64-stm32mp1-openstlinux-6.6-yocto-scarthgap-mpu-v24.11.06.tar.gz: gzip compressed data, from Unix, original size modulo 2^32 934342372 gzip compressed data, unknown method, ASCII, was "", encrypted, from FAT filesystem (MS-DOS, OS/2, NT), original size modulo 2^32 934342372
But you get rid of the extension or pass it through `gunzip` first, then everything works:
$ gunzip en.SDK-x86_64-stm32mp1-openstlinux-6.6-yocto-scarthgap-mpu-v24.11.06.tar.gz
So it's either the command is not correct, or a compression is missing. Either way, I suggest to use tar.xz instread, because it provides a better compression ratio, and tar xJf for extraction respectively.
- Labels:
Bug-report
Documentation
‎2025-01-03 3:16 AM
Hello @UVV ,
Thank you for reporting this issue.
We are looking at it to fix it.
Best Regards,
Kevin
‎2025-01-08 2:29 AM
Hello @UVV ,
Our technical team is investigating the issue that is not yet reproducible and may depend on some configuration at user end.
Could you please help us to fix this and provide details about your configuration: machine, browser, location (IP), time of download ?
Thanks a lot.
Charles
‎2025-01-08 9:00 AM - edited ‎2025-01-08 9:00 AM
Original download: 02.01.2025, 11:27 CET, MacOS, Firefox 133.0.3, Belgian IP address (VPN).
Tried again: 08.02.2025, 17:56 CET, Linux, Firefox 115.9, German IP address (no VPN).
Same result.
