2022-09-23 12:52 AM
Hi all
I have a new board of STM32MP157C, But I found the eMMC's pin in board is not the default pin. If I want to boot from eMMC what I should do? write the otp to set pin of eMMC and set the device tree. is that enough ?
2022-09-23 07:50 AM
Hi @WHe.1
This post might help you
https://community.st.com/s/question/0D53W00001YdEeASAV/can-we-swap-sdmmc-pins-in-our-design-
Regards.
In order to give better visibility on the answered topics, please click on 'Select as Best' on the reply which solved your issue or answered your question. See also 'Best Answers'
2022-09-23 07:50 AM
Hi @WHe.1
Regards.
