How do I build this example project?
‎2022-01-28 1:41 PM
When I hit the build button, I get "Nothing to build for project DK2_TIMER1_OpenAmp_Solution", the Debug folder is also empty, should this be populated or do I need to generate it somehow?
https://www.youtube.com/watch?v=PsiFDHH87vo&list=PLnMKNibPkDnFeV4sBarnsAtFTg7h6V-9_&index=11
- Labels:
STM32MP15 Lines
‎2022-02-15 9:30 AM
Hello @msche.1​ ,
Sorry for the late reply.
I was finally able to work on your problem by installing the VM and trying to build.
I encountered the same issue than you by using the content described in the video.
The video was made with ecosystem 1.0.0 which is very old and with the tool STM32Workbench, which is now replaced by STM32CubeIDE, so the project syntax was different. That is why you were enable to build the project.
Procedure:
- Download the latest Virtual machine to realize the workshop, V3.1: https://drive.google.com/drive/u/0/folders/1bHzBRWokb_ouFOAHMPusBmjYLhF4rw5h
- Then it is not obvious, but you have to go in the folder "OpenSTLinux_3_0_Update":
https://drive.google.com/drive/u/0/folders/1KQGGmHOE9Zq44O6KfNqAYMaGgkYwt42h
and download the folder "WorkshopUpdates_3_0_0-1.zip", which contains all the projects updated for the latest OSTL version.
- You will find the folder "WorkshopSlides" with all the slides updated, so I advise you to use them in the same time than the video. You can also read the "README.TXT" inside the folder.
- Go inside the folder "InputLabMaterial/Lab-M4" and unzip STM32Cube_FW_MP1_handsOn.zip
- Finally, if you import the project in CubeIde 1.8.0, you will see 3 projects:
Click on finish and select "DK2_TIMER1_OpenAmp_Solution_CM4" in the project explorer and click on the build icon (hammer):
You must be able to build the project.
If you want to do the other video, please keep in mind that the slides in the "WorkshopSlides" folder are the one up to date.
Hope it helps,
Regards,
Kévin
In order to give better visibility on the answered topics, please click on 'Select as Best' on the reply which solved your issue or answered your question. See also 'Best Answers'
‎2022-01-31 9:11 AM
Hello @msche.1​ ,
I assume that you followed the step from the video.
Please can you send me a screenshot of your project explorer on the left side of CubeIde and the complete log from the CubeIde Console when you hit the hammer (build button).
Regards,
Kevin
‎2022-01-31 9:44 AM
Yes, I followed the steps. Basically just unzipped, imported and built.
‎2022-02-15 9:30 AM
Hello @msche.1​ ,
Procedure:
Hope it helps,
Regards,
Kévin
‎2022-02-23 3:08 AM
Hello @msche.1​ ,
Did it fix your issue?
Regards,
Kevin
