STM32MP1 internal temp sensor support removed from latest kernels?
Grodriguez
Previous kernel versions had support for the STM32MP1 internal temp sensor. See:
Apparently this has been removed in later kernels. Isn't this supported anymore ?
Thanks,
Guillermo
OlivierK
Hi Grodriguez (Community Member),
The ADC temp sensor support has been removed from OpenSTLinux versions > 1.2.0, however you can use instead the Digital temperature sensor which is much more accurate.
https://github.com/STMicroelectronics/linux/blob/v5.4-stm32mp/arch/arm/boot/dts/stm32mp151.dtsi
https://github.com/STMicroelectronics/linux/blob/v5.4-stm32mp/Documentation/devicetree/bindings/thermal/stm32-thermal.txt
Olivier
