I am wondring if the board stm32mp157a-dk1 supports android booting system ? how to get the android enviroment ?
AFard.1
 stm32mp157a-dk1 board
Erwan SZYMANSKI
Hello @AFard.1​ ,
For low performances and bad user experience reasons, ST chose to not support Android on this platform anymore.
Kind regards,
Erwan.
4 REPLIES 4
Erwan SZYMANSKI
Hello @AFard.1​ ,
Kind regards,
Erwan.
Hello Erwan,
thank you very much for the quick reply,
Actually we are developing a custom hardware based on same soc ​STM32MP157 Arm®-based dual Cortex®-A7 32 bits + Cortex®-M4 as stm32mp157a-dk1 dev board , I want to prepare the android environment for the dev board before doing the bring up of our custom hardware, do you have any suggestions please?
best regards
ahmed fardi​
Hello @AFard.1​ ,
As I said, we will not be able to provide a lot of support on Android. The only little tips that we can give are the ones below:
  • Android can only be used for very simple UI, that are not too complex in term of animations etc.
  • We recommend a mobile screen size maximum
  • We recommend 1GDDR in 32 bits.
Moreover, for security reason, I am not sure that you will be able to boot Android on stm32mp157a. Only c and f should be usable.
I hope that it will help you a little bit in your bring up process.
As mentioned on the wiki, if you need more support, you can contact our partner Witekio.
Kind regards,
Erwan.
Hello Erwan , we switched to use the eval board STM32MP157f-EV1 , based on it w started the hardware dev .
I downloaded the st-android-11.0.0-2021-01-29 android soft , and flashed the baord , the switches are configured to boot from emmc , the startup of android system is ok but without screen , the dispaly is white , the tactil working fine i can see by the logcat all the services are fine even the ST laucher com.stmicroelectronics.stlauncher.
Any help please ? , i tried to build locally a soft , flashed to sdcard but i faced the same problem on the dispaly .
I attached the full log here
