Using ADC with DMA on M4 causes DMA transfer error
‎2020-06-22 5:26 AM
We are trying to use circular DMA to transfer data from ADC1 into a buffer in MCU SRAM using CubeMX-generated code to configure the ADC and DMA. The DMA stream encounters a transfer error on transferring the first item. I have tried clearing the DMA error flags before starting the transfer with HAL_ADC_Start_DMA but that did not help.
The device is an STM32MP157C running in Production mode. ADC1 and DMA2 are assigned to the M4 core.
Using a debugger it can be seen that the peripheral address and memory address are configured correctly for the DMA stream. However, the DMA_HWCFGR1 register for DMA2 shows that all streams are in double-buffer mode despite the DBM bit being cleared in the stream configuration register, is this normal?
CubeMX-generated code:
static void MX_ADC1_Init(void)
/* USER CODE BEGIN ADC1_Init 0 */
/* USER CODE END ADC1_Init 0 */
ADC_MultiModeTypeDef multimode = {0};
ADC_ChannelConfTypeDef sConfig = {0};
/* USER CODE BEGIN ADC1_Init 1 */
/* USER CODE END ADC1_Init 1 */
/** Common config
hadc1.Instance = ADC1;
hadc1.Init.ClockPrescaler = ADC_CLOCK_SYNC_PCLK_DIV2;
hadc1.Init.Resolution = ADC_RESOLUTION_12B;
hadc1.Init.ScanConvMode = ADC_SCAN_ENABLE;
hadc1.Init.EOCSelection = ADC_EOC_SINGLE_CONV;
hadc1.Init.LowPowerAutoWait = DISABLE;
hadc1.Init.ContinuousConvMode = ENABLE;
hadc1.Init.NbrOfConversion = 8;
hadc1.Init.DiscontinuousConvMode = DISABLE;
hadc1.Init.ExternalTrigConv = ADC_SOFTWARE_START;
hadc1.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE;
hadc1.Init.ConversionDataManagement = ADC_CONVERSIONDATA_DMA_CIRCULAR;
hadc1.Init.Overrun = ADC_OVR_DATA_PRESERVED;
hadc1.Init.LeftBitShift = ADC_LEFTBITSHIFT_NONE;
hadc1.Init.OversamplingMode = DISABLE;
if (HAL_ADC_Init(&hadc1) != HAL_OK)
Error_Handler();
/** Configure the ADC multi-mode
multimode.Mode = ADC_MODE_INDEPENDENT;
if (HAL_ADCEx_MultiModeConfigChannel(&hadc1, &multimode) != HAL_OK)
Error_Handler();
/** Configure Regular Channel
sConfig.Channel = ADC_CHANNEL_10;
sConfig.Rank = ADC_REGULAR_RANK_1;
sConfig.SamplingTime = ADC_SAMPLETIME_64CYCLES_5;
sConfig.SingleDiff = ADC_SINGLE_ENDED;
sConfig.OffsetNumber = ADC_OFFSET_NONE;
sConfig.Offset = 0;
if (HAL_ADC_ConfigChannel(&hadc1, &sConfig) != HAL_OK)
Error_Handler();
/* Other channels omitted here */
void HAL_ADC_MspInit(ADC_HandleTypeDef* hadc)
if(hadc->Instance==ADC1)
/* USER CODE BEGIN ADC1_MspInit 0 */
/* USER CODE END ADC1_MspInit 0 */
/* Peripheral clock enable */
HAL_RCC_ADC12_CLK_ENABLED++;
if(HAL_RCC_ADC12_CLK_ENABLED==1){
__HAL_RCC_ADC12_CLK_ENABLE();
/* GPIO init omitted here */
/* ADC1 DMA Init */
/* ADC1 Init */
hdma_adc1.Instance = DMA2_Stream0;
hdma_adc1.Init.Request = DMA_REQUEST_ADC1;
hdma_adc1.Init.Direction = DMA_PERIPH_TO_MEMORY;
hdma_adc1.Init.PeriphInc = DMA_PINC_DISABLE;
hdma_adc1.Init.MemInc = DMA_MINC_ENABLE;
hdma_adc1.Init.PeriphDataAlignment = DMA_PDATAALIGN_HALFWORD;
hdma_adc1.Init.MemDataAlignment = DMA_MDATAALIGN_HALFWORD;
hdma_adc1.Init.Mode = DMA_CIRCULAR;
hdma_adc1.Init.Priority = DMA_PRIORITY_HIGH;
hdma_adc1.Init.FIFOMode = DMA_FIFOMODE_DISABLE;
if (HAL_DMA_Init(&hdma_adc1) != HAL_OK)
Error_Handler();
__HAL_LINKDMA(hadc,DMA_Handle,hdma_adc1);
/* USER CODE BEGIN ADC1_MspInit 1 */
/* USER CODE END ADC1_MspInit 1 */
static void MX_DMA_Init(void)
/* DMA controller clock enable */
__HAL_RCC_DMAMUX_CLK_ENABLE();
__HAL_RCC_DMA2_CLK_ENABLE();
/* DMA interrupt init */
/* DMA2_Stream0_IRQn interrupt configuration */
HAL_NVIC_SetPriority(DMA2_Stream0_IRQn, 5, 0);
HAL_NVIC_EnableIRQ(DMA2_Stream0_IRQn);
/* DMA2_Stream1_IRQn interrupt configuration */
HAL_NVIC_SetPriority(DMA2_Stream1_IRQn, 5, 0);
HAL_NVIC_EnableIRQ(DMA2_Stream1_IRQn);
/* DMA2_Stream2_IRQn interrupt configuration */
HAL_NVIC_SetPriority(DMA2_Stream2_IRQn, 4, 0);
HAL_NVIC_EnableIRQ(DMA2_Stream2_IRQn);
/* DMA2_Stream3_IRQn interrupt configuration */
HAL_NVIC_SetPriority(DMA2_Stream3_IRQn, 4, 1);
HAL_NVIC_EnableIRQ(DMA2_Stream3_IRQn);
/* DMA2_Stream4_IRQn interrupt configuration */
HAL_NVIC_SetPriority(DMA2_Stream4_IRQn, 4, 0);
HAL_NVIC_EnableIRQ(DMA2_Stream4_IRQn);
/* DMA2_Stream5_IRQn interrupt configuration */
HAL_NVIC_SetPriority(DMA2_Stream5_IRQn, 4, 1);
HAL_NVIC_EnableIRQ(DMA2_Stream5_IRQn);
/* DMA2_Stream6_IRQn interrupt configuration */
HAL_NVIC_SetPriority(DMA2_Stream6_IRQn, 5, 1);
HAL_NVIC_EnableIRQ(DMA2_Stream6_IRQn);
void DMA2_Stream0_IRQHandler(void)
/* USER CODE BEGIN DMA2_Stream0_IRQn 0 */
/* USER CODE END DMA2_Stream0_IRQn 0 */
HAL_DMA_IRQHandler(&hdma_adc1);
/* USER CODE BEGIN DMA2_Stream0_IRQn 1 */
/* USER CODE END DMA2_Stream0_IRQn 1 */
- Labels:
ADC
DMA
STM32Cube MPU Packages
STM32MP15 Lines
‎2022-01-05 7:11 AM
Hi @MMevo.1​ , @PatrickF​ ,
Yes, ST Support helped me with this. The missing piece was to add DMA2 to MCU isolation in the TF-A device tree.
To the etzpc node, add:
DECPROT(STM32MP1_ETZPC_DMA2_ID, DECPROT_MCU_ISOLATION, DECPROT_UNLOCK)
‎2020-06-24 3:00 AM
Hi @Emma​ ,
In you code fragment you didn't provide the DMA settings located in file stm32mp1xx_hal_msp.c
Could you for better inspection send the original ioc file?
I tend to think it's just matter of settings - the M4 core and this ADC DMA feature has been used frequently.
Best regards,
MIlan
‎2020-06-24 8:00 AM
Hi @mleo​ ,
Please find the ioc file attached.
(In the project you can see that I2C1 and I2C3 are also configured to use DMA, but I couldn't get it working so I switched to using interrupts for the time being. I haven't looked into why the I2C DMA didn't work.)
Best Regards,
Emma
‎2020-09-10 6:47 AM
I haven't been able to solve this and I'm also having the same problem with the DAC: Transferring data from a buffer in MCU SRAM to the DAC (DHR12R1) using DMA2 generates a DMA transfer error on the first data item.
The only DMA transfer I've been able to get to work on the M4 core is a memory-to-memory transfer. Because of this I'm assuming that the transfer error is caused by a bus error when accessing the ADC/DAC data registers and not when accessing the MCU SRAM.
What would cause such a bus error? I'm using half-word alignment which worked fine on an STM32F427 but I've also tried word alignment to make sure it's not an alignment issue.
‎2022-01-03 7:31 AM
Hi Emma,
I am experiancing the same issue with STM32H743-
did you manage to solve this problem?
Best Regards,
Maor
‎2022-01-04 12:06 AM
Hi @MMevo.1​, @Emma​ , did you also enable the ADC1 global interrupt (or relevant peripheral interrupt you want to use with DMA) in CubeMx ?
@MMevo.1​ , for further support on STM32H7, please enter a question on STM32 MCUs community
Regards.
‎2022-01-05 7:11 AM
‎2022-01-05 7:25 AM
In order to give better visibility on the answered topics, please click on 'Select as Best' on the reply which solved your issue or answered your question. See also 'Best Answers'
‎2022-01-05 7:25 AM
‎2022-01-05 7:29 AM
not at all, this is related only to STM32MP1 series Cortex-A7 side with Linux.
Not relevant for STM32H7.
Maybe worth that you look at existing examples provided in STM32CubeH7 and if not enough please enter a question on STM32 MCUs community
Regards.
