STM32_Programmer_CLI:command not found
Pooja321
we are following all step i.e mentioned in st.wiki. we have installed the stm32 cubeprogrammer but commant not working .at where i am doing wrong?
3 REPLIES 3
Erwan SZYMANSKI
Hello @Pooja321 ,
After exporting your PATH variable, can you do an echo $PATH command and an ls <your_cube_programer_path> and show me outputs ?
Rgs,
Erwan
Jesus5611
Hello @Erwan SZYMANSKI
I am having the same issue. Here are the outputs to the commands you suggested.
Thank you,
Jesus
Hello @Jesus5611 ,
In you case, this is not an error of PATH variable content, but more an installation issue. It tells you that libraries for Qt6 are missing.
I advise you to reinstall your tool.
Kind regards,
Erwan.
