OPTEE panic in core_init_mmu_map
‎2023-12-04 09:56 AM
Hi, I have a custom board with a stm32mp153. I was able to get past the trusted bootloader and into optee. It builds the mmu map and then panics when checking it. I am able to partially step through building the table and the memory starts to get corrupted but I can't see why. I also have a 157-ev which works fine when I build for that on the same dev machine. I am looking for possible clues on where to go from here.
- Labels:
OP-TEE
‎2023-12-08 12:05 AM
Hi @dkal
if you are writing to DDR, maybe double check the correct DM Vs DQ/DQS wirings on your schematics. We had seen similar behavior when customers swapped Data Mask and Bytes which mean x32-bits write works but not bytes.
Regards.
‎2023-12-04 01:56 PM
I've tracked the issue down to memmove not working properly, why would it be fine in stm32mp157 and not fine in stm32mp153?
‎2023-12-04 05:49 PM
More specifically, the memmove is filling the destination with garbage even though the source and destination pointers are valid.
‎2023-12-05 08:06 PM
It seems that single byte copies are the issue, when it can do a more optimized copy with longs, that memory is correct.
‎2023-12-07 08:20 AM
I am going to assume that this is a RAM issue and am now trying the DDR utility.
Hi @dkal
Regards.
‎2023-12-08 11:25 AM
Thank you, we will check.
‎2023-12-08 01:18 PM
We have
DDR_DQM0 connected to UDM
DDR_DQM1 connected to LDM
Hardware guys said they did it that way because thats how the eval board is connected, it looks that way in the schematic, is this correct?
‎2023-12-08 02:49 PM
Oh the DQM0 and DQS0 are not consistent with upper and lower.
