2023-06-28 11:14 AM
Hello everyone
The "bitbake <my_recipe>" process ends without errors but the "/usr/local/" folder of the image is empty (there are no ST demo folders and no "weston-start-at-startup" folder). Why?
2023-06-29 7:49 AM
Thank you for your availability. I cleaned and rebuild the yocto image and now the "/usr/local" folders are present.
Many thanks
2023-06-28 2:59 PM
Hi @nataut ,
What is the image you compiled ? Because here you tell me about a bitbake recipe compilation, but do you compile the complete image provided by ST ? Or did you make your own image ?
Whatever, you have to know that everything installed inside /usr/local in Yocto is overwritten by the userfs recipe.
To take an example, I invite you to take a look at /meta-st/meta-st-stm32mp/recipes-st/images/st-image-userfs.bb. I think it will help you to understand how to manage your userfs part with Yocto.
Kind regards,
Erwan.
2023-06-28 11:17 PM
Hello @Erwan SZYMANSKI
I'm talking about a Yocto image with bsp openstlinux-4.19-thud. Until now those folders were always created. I haven't changed anything in the meta-st layer. In the last build I only changed my own device tree.What can be the reason? What should I check?
Many thanks
2023-06-28 11:50 PM
Hello @nataut ,
ST does not support nor openstlinux-4.19 or openstlinux-5.4 anymore. I highly advice you to upgrade your OSTL version to 4.1 to get support.
Kind regards,
Erwan.
2023-06-29 2:14 AM
It is difficult for me to update the openstlinux version.
I think my question is a general one that applies to the other versions as well.
Can anyone help me?
2023-06-29 3:49 AM
@nataut ,
Do you build st-image-weston as your complete image ?
Kind regards,
Erwan.
2023-06-29 7:49 AM
Many thanks
2023-06-29 8:35 AM
@nataut ,
Thanks for your quick feedback.
Kind regards,
Erwan.
