2024-07-03 2:11 AM
Hello all,
I'm using STM32MP135F-DK, taking picture with GC2145 camera and converting 1600x1200 raw image to png/jpeg formats to use later. I'm doing these according to the document at below link:
https://wiki.st.com/stm32mpu/wiki/STM32MP13_V4L2_camera_overview
I calculated how much time spent for below script:
##### 2 MP Setup
media-ctl -d /dev/media0 --set-v4l2 "'gc2145 1-003c':0[fmt:RGB565_2X8_BE/1600x1200@1/20 field:none]"
media-ctl -d /dev/media0 --set-v4l2 "'dcmipp_parallel':0[fmt:RGB565_2X8_BE/1600x1200]"
media-ctl -d /dev/media0 --set-v4l2 "'dcmipp_parallel':1[fmt:RGB565_2X8_LE/1600x1200]"
media-ctl -d /dev/media0 --set-v4l2 "'dcmipp_dump_postproc':0[fmt:RGB565_2X8_LE/1600x1200]"
##### 2 MP Capture
v4l2-ctl --set-fmt-video=width=1600,height=1200,pixelformat=RGBP --stream-mmap --stream-count=1 --stream-to=grab-1600x1200-rgb565.raw
##### 2 MP Convert
gst-launch-1.0 filesrc location= grab-1600x1200-rgb565.raw blocksize=3840000 ! "video/x-raw, format=(string)RGB16, width=(int)1600, height=(int)1200, framerate=(fraction)20/1" ! videoconvert ! pngenc ! filesink location=grab-1600x1200-rgb565_ex1.png
And the results are:
These results are too much for me. I saw that too much time spent especially on convert section.
I know that decreasing resolution might be one of the solutions, but is there any other suggestions to reduce that time?
2024-07-08 8:17 AM
Hello @alpka ,
Unfortunatly, no we have no other recommendation. The Galcore camera is the one we embed by default on STM32MP13 now and that is tested by ST, but we have no equivalent of the OV5640 on our side to propose. It will be up to you to chose a one that will reach your requirements.
Kind regards,
Erwan.
2024-07-03 12:55 PM
Hi alpka
This post has been escalated to the ST Online Support Team for additional assistance. We'll contact you directly.
Kind Regards
Joe
STMicro Support
2024-07-04 11:22 PM
Hello @alpka ,
Please find out the outcomes from the expert who took a look at your issue :
I hope it will help you yo go forward,
Kind regards,
Erwan.
2024-07-05 1:23 PM
Hi Erwan,
Yes I tried the JPEG, and the JPEG conversion is faster than PNG. I will also check other suggestions.
As far as I know, OV5640 can directly take JPEG images but it's a end of life product. Do you have any other 5 MP camera suggestions?
Thank you.
2024-07-08 8:17 AM
Hello @alpka ,
Kind regards,
Erwan.
