2021-02-24 05:06 AM
Hello. What is the exact value of T_coeff_vrefint? I'm planning to use internal reference voltage buffer (VREFBUF) output pin in my application.
2021-02-24 06:36 AM
Hi @Paweł Straszak ,
Tcoeff_vrefint is provided in the table Embedded internal voltage reference of the same datasheet:
-Amel
2021-02-24 06:36 AM
-Amel
2021-02-24 06:38 AM
Thank You. I was unable to find this information in the specification.
2021-02-24 06:49 AM
You are welcome. It is in the datasheet of the product.
I assume my reply answered your request, so I'll select it as a best answer (clicking on "Select as Best" option).
-Amel
2021-02-24 08:06 AM
One more question: is V_ref voltage equal to 1,212 V or to 2,048 V / 2,5 V?
