STM32WLxx DFU Error
ethan2
I ported the SBSFU project to the LoRaWAN_AT_Slave routine, and tested DFU normally and it worked fine, but when I used the wrong file to upgrade, such as readme.txt, the upgrade process ran for a while, and then stopped, showed " Fw header authentication error" and "No valid FW found in the active slots nor new FW to be installed". As a result, the firmware of my application cannot run normally, and I must re-DFU the normal firmware before I can restore it. Is this normal?
1 REPLY 1
STTwo-32
Hello @ethan2
Please add more details on your configurations what steps have you been following, what is the readme you are toking about, what is the "Wrong file"...
Best Regards.
STTwo-32
