STM32WB5MM-DK Unable to run the BLE_LLD_Chat example generated by STM32Cubeide
Csu.11
 * @brief Check if the Coprocessor Wireless Firmware loaded supports Thread
 *        and display associated informations
 * @param  None
 * @retval None
void CheckWirelessFirmwareInfo(void)
  WirelessFwInfo_t  wireless_info_instance;
  WirelessFwInfo_t* p_wireless_info = &wireless_info_instance;
  if (SHCI_GetWirelessFwInfo(p_wireless_info) != SHCI_Success)
    APP_BLE_LLD_Error(ERR_BLE_LLD_CHECK_WIRELESS, 0);
  else
    switch(p_wireless_info->StackType)
    case INFO_STACK_TYPE_BLE_PHY_VALID :
      break;
    default :
      break;
After debug, it was found that the CheckWirelessFirmwareInfo() function reported an error, and the StackType read by the SHCI_GetWirelessFwInfo() function was incorrect.
1 REPLY 1
Imen.D
Hello @Csu.1​ ,
Which Cube package version are you using ?
Please make sure to use the latest release of Cube package and CubeIDE tool.
Imen
Imen
