2023-01-16 01:05 AM
I can't get a current lower than 108µA in stop1 mode. It's expected 3µA in the datasheet.
I set all pin in analog input mode, disable the debug in low power mode.
I try with the NUCLEO Board as explain in the article number n°2190.
I also removed all JP2 jumpers to decrease the current consumption of the shift level.
Has anyone always succed to get 3µA in stop1 mode with this MCU.
Thanks,
2023-01-16 04:33 AM
CPU2 was not in shutdown mode !
Now with CPU2 in shutdown mode (LL_C2_PWR_SetPowerMode(LL_PWR_MODE_SHUTDOWN);) current consumption is 3µA for CPU1 stop1 mode.
Sorry
2023-01-16 04:33 AM
Sorry
