STM32WB15 cannot connect stlink v2
Erdincca
I encounter the following error when connecting STM32WB15 to ST-Link V2.
Error: No STM32 target found! If your product embeds Debug Authentication, please perform a discovery using Debug Authentication
only VDD,GND, and SWIO and SWCLK pins connected..
package is ..UFQFPN48
what is problem..?
Erdincca
i solved this problem... Proble is SW Fequency... Low frequency is working..
Thanks..
6 REPLIES 6
Guru
  • Is this a custom board?
  • Are you using STM32CubeProgrammer? Does it output the target voltage? Is that voltage as expected?
  • Are you using a genuine programmer? Link to it.
Andrew Neil
Evangelist III
Does it?
If 'yes':
did you do that?
Have you tried adding Reset?
yes customboard. i use stm32cubeprogrammer. output voltage 3.3v. original stlink v2 use..
Perhaps a schematic error. Perhaps a hardware error.
Erdincca
Thanks..
@Erdincca  Good to hear it's solved.
Now please mark the solution - so that others who come here with the same problem can find it.
