Secure Flash Area Approach
‎2024-03-04 04:44 PM
Hi.
Something that needs to be done FOTA while using the code, so you need to write the flash area behind it.
I want to use a sash area, but it is impossible to access the document.
Please tell me if you have a way to do it.
STM32WB series
‎2024-04-22 10:09 PM
I wanted to flash write in the WirelessStack area, but I gave up because I found it impossible.
Thank you.
‎2024-04-18 09:16 AM
Hello @songkw
Can you give more details about your request?
Best Regards.
STTwo-32
Thank you.
