Reg: STM32WLE5 MUC delay used for Lora SubGHz_Phy.
Subramanya A
Hi Team,
I'm using STM32WLE5 MUC for Lora communication (SubGHz_Phy), I want to know is there a way to use Systick instead of timer ?
This is because I used RTC to some other use case. kindly share me the way for the same.
Thanks,
Subramanya A
I see no response from the team,
Reference for some one looking for same: I was able to achieve Lora communication without middleware (radio.c/h, which is intern using timer (RTC) for delay). below is the article which explains to achieve the same.
https://forum.digikey.com/t/using-the-low-level-sub-ghz-radio-driver-for-the-stm32wl-series/18253
