STM32WB15cc - Wake up periodically with RTC and check for event (battery charged), disable rtc if event has happened
‎2023-03-20 8:52 AM
I am trying to use as little power as possible, I want my board to wake up every 30 seconds or so, check if battery has been sufficiently charged, if not, go back to sleep, if it has then turn off rtc and do a function. Is it possible to disable rtc whilst running?
- Labels:
RTC
STM32WB series
‎2023-03-21 7:15 PM
Dear Liam
Our team is checking into this inquiry and we will be in touch with you shortly.
Kind Regards
Joe WILLIAMS
STMicro Support
‎2023-03-22 11:14 AM
What makes you think the RTCEN bit in RCC_BDCR register cannot be cleared?
‎2023-03-31 7:26 AM
You can disable the RTC by setting the RTCSEL in RCC_BDCR register at no clock.
Best Regards
‎2023-04-01 2:34 AM
Bits 9:8 RTCSEL[1:0]: RTC clock source selection
Set by software to select the clock source for the RTC. Once the RTC clock source has been selected, it cannot be changed anymore unless the Backup domain is reset, or unless a failure is detected on LSE (LSECSSD is set). The BDRST bit can be used to reset them.
